Sony KDL-37L5000 37 in. LCD TV Logo
Posted on Mar 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote doesn't work. - Sony KDL-37L5000 37 in. LCD TV
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Mar 19, 2011
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957493
Points
33084
Please replace batteries in remote and check.
Try another Sony tv remote or Sony dvd player remote that also has power, volume and channel up/ down buttons for Sony tv.
If no remote works on this tv then it would be bad remote sensor located on front of tv, its small circuit board that will be replaced to solve the issue and local tv repair shop will help you if you are not familiar with electronics stuff repair.
Hope this will help.
Thanks.
Testimonial: "thank you very much, I did everything you recommend me and it seems the infrared detector doesn't work, I'll take the tv to dealer, thanks gbye"
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
94 full size blazer keyless remote doesn't work.
Does the spare remote work? Have you tried to reprogram it? These remotes are very cheaply made and prone to key pad failure. To program the remote click this LINK, if that doesn't work buy anew one on eBay for cheap.
Wii remote not working?
You got to sync the remote with your console to activate the remote
The remote for my samsung ht-tx72 doesn't work even though the tv and dvd reciever lights on the remote work. It doesn't turn on my home theater system. Do I need to reprogram it?
Possibly. Maybe it's malfunctioning.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
I cannot turn on my surround sound on my Philips MCD700 Stereo using the remote, any ideas???????
So are you saying the remote doesn't work or that the unit itself doesn't work? Walk over to it and press the power button.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
