I have an ariston margherita wsher dryer and i put it on to start a cycle. it did start but in the middle of the program the dial started turning and now the cycle will not finish and the dial is continuously turning.....any suggestions on how i can reset it?
Hiya
to reset the dial, switch the power off, then turn the dial to a dot on the selection then switch the power on, the light should flash about 3-4 times this should be it reset.
for the machine to start doing this mid cyle though usually indicates something is wrong, i would hazard a guess at the pump filter is blocked and the mahine was trying to drain at the time it started clicking.
the best thing to do is empty the machine manually by placing the outlet hose into a bucket or large dish, once empty remove the plastic kick plate on the bottom of the machine and behind this you will find the filter.
before you unscrew the filter you will need to place some towels or old cloths on the floor as there will still be water left in the pipes, remove filter and any foreign objects (possibly coins, hair clips etc) and then screw back in. job done.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
I hhve the same problem - did this work??????
The dial was turning continuously, so I reset the machine, but now when I put it on a cylce it starts to work, and then stops completely. What should I do?
