Sylvania 6319CE 19 in. TV/VCR Combo Logo
Posted on Mar 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost remote can't program channels - Sylvania 6319CE 19 in. TV/VCR Combo
mega_mind
Level 2:
Sergeant:
  • Expert 162 Answers
  • Posted on Mar 19, 2011
mega_mind
Expert
Level 2:
Sergeant:
Answers
162
Questions
0
Helped
23462
Points
516
You can go and buy universal remote control. best buy or radio shack will have them in stock.
1helpful
NEED CODES FOR RCA CONVERTER BOX TO PROGRAM TV TO REMOTE
Good day,
I might be missing something here, but if YourTV has the basic controls on the TV itself, such as on/off volume, and channel select, then just turn on tv, and set it to channel 3.
Use your converter box remote to scan for channels, and other options it has as needed.
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Toshiba 14DLV75 lost remote Control
Get an inexpensive universal remote and program it for your Toshiba. The instructions for the remote will lead you through programming for your Toshiba.
Auto channel program
Universal remotes don't like combo units.If your original reomte worked before you lost it you are going to have to buy the original remote to solve your problem.
1helpful
Lost remote programing directions
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Not all channels are programmed
get a universal remote,,is about the only way,,unless there is a menu button on the vcr
1helpful
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
2answers
Remote control lost programing
this is embedded in the control chip of the remote and is rom..best to replace remote i personnaly have lots of luck repairing usually find cracked solder joints..remotes witstand lots of abuse but do break! john
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
