Try updating it by using your PC and a USB flash drive. Follow the instructions on the Playstation webite under the update quick click button on their main page.
Hard boot the PS3, turn off the PS3 to stand-by, flip off the back
switch and remove the power cord. Then shut off your modem/router, for
about 5 minutes, then turn the modem back up first and let it sync, then
turn the router back on(if using one) and let it sync. Reconnect your
power cable and flip the back switch up again. Then make a new network
connection.
This is an update error. You should have gotten this error while trying to update your system. The easiest way to resolve that I've found is to powercycle (unplug and leave off for about a minute) your modem/router as well as your PS3 and try updating again.
Its best you log a case with HP support. If your system is still under warranty or if you bought support along with the system, they will fix the problem for you.
Don't worry. There is a huge problem occurring right across the board at this very moment with the PSNNetwork. Some consoles are not synchronising properly due to an internal clock error which is causing problems exactly like you describe. It is expected that Sony will soon have this resolved.
For a full breakdown please look at this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
This is a worldwide problem with the Sony Network today which might be due to system maintenance. Sony is working on the problem and the problem will be rectified soon.Kindly wait for further announcements from Sony. Your system should work normally when the issue is fixed.
Hi This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again. Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
A Code 10 error usually occurs due to:
Missing device driver Malfunctioning device driver Incomplete device driver files
to fix it..........
updating the device driver for the faulty device
1st) To update the driver, select the System option from the Control Panel. 2nd) In the System Properties dialog box, select the Hardware tab, 3rd) select the Device Manager button.
4th) Scroll through the Device Manager window and identify the faulty hardware device.
5th) Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
