Master
- Posted on Mar 18, 2011
Re: Lens error. The lens are stuck
Hello and Welcome
The most common cause for a Lens error:
Misaligned Lens rings
Sand and grid wedged in between the lens and the barrel.
Dropping the camera
Ran down battery
The following solutions are there by which you may Fix the lens error
Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
If the batteries ran down while you were taking photos with the lens
extended, you might also get this error. Remove the the memory card and
replace the batteries with a fresh recharged set. Try to power on the
unit with the fresh set of batteries while the memory card is removed
Connect your camera to your computer using your USB DATA cable which
came with the camera. Once the camera gets power in this mode, the
screen should stay off, hence, supplying the lens with more power to
push or pull out/in
Place the camera on a sturdy table with the lens pointing to the
ceiling. With a fresh set of batteries installed(Do this without a
memory card) hold down the shutter button while you power on the unit
Now, you can either use a compressed air canister to blow around the
lens area. This will result in the sand or dust particles to be blown
out of the area between the lens and the barrel. Or, you can use a
vacuum and and carefully place the nozzle around the lens to out the
particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly,
Further assistance, I am here to help.
Thanks and Keep visiting FixYa
Concerned: Uxair Shah
