Question about Kenmore 66222 Microwave Oven
Kenmore Model 721.66222500 just suddenly stopped working. No light, no power, no nothing.
    New Friend:
I just had same problem happen on a Kenmore Model 721.89940490. I took off top panel and control panel. Behind control panel is a ceramic fuse. I pullud it out and checked with my mutimeter for continunity and it is blown. Since it is 20 years old I will get a new fuse and replace it. If it works good, if not I will have to go buy a new one to put under the cabinet. My contractor that built my house in 1994 directed wired it but I\'ll spend a little extra and put a plug in the cabinet, if I have to replace it. I suspect I won\'t but there is still that possibility.
Posted on Jul 14, 2014
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: kenmore microwave #721-89941-1490
There is an internal fuse, plus one or two thermostats or thermal cutouts.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
Posted on Jun 29, 2008
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: yesterday microwave worked fine today it doesnt
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
Anonymous
SOURCE: kenmore microwave model 721-63252301 - no heat
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Posted on Jun 06, 2009
SOURCE: wjusino just asked: My kenmore microwave doesnt heat.
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on Jan 26, 2010
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | Microwave Ovens
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore 66222 Microwave Oven Logo
376 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
