I have a simular problem that someone else has. My washer will not discharge the water. I turn the knob to try to spin the water out it will run but not discharge the water. My husband thinks that the pump is not working. Help.
Is the discharge hose higher than the machine? If it is Lower it will never fill. Don't think there is a shut off in the hose to stop the water discharge.
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program
Knob. To START THE TEST:
• On non-digital display models, turn the
Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program
Knob to start position, Touch Up.
• Press Pause/Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and
Pause Cancel buttons until LEDs start
sequentially chasing, then release buttons.
1. All the LEDs will sequentially light. Pressing a
button below a light cluster will light all the LEDs in
that cluster at one time to confirm functionality.
2. Turn the program knob (1) click clockwise from the
start position. The hot water solenoid will activate
and hot water should enter through the detergent
compartment.
3. Turn the program knob (2) clicks from the start
position. The bleach water solenoid will activate and
cold water should enter through the bleach
compartment.
4. Turn the program knob (3) clicks from the start
position. The bleach and the wash water solenoids
will activate and cold water should enter through the
softener compartment.
5. Turn the program knob (4) clicks from the start
position. The door lock solenoid will activate.
6. Turn the program knob (5) clicks from the start
position. The door lock solenoid will deactivate and
the loading door can be opened.
7. Turn the program knob (6) clicks from the start
position. The washer will fill and tumble.
8. Turn the program knob (7) clicks from the start
position. The washer will fill and spin (leakage test).
9. Turn the program knob (8) clicks from the start
position. The drain pump and door lock solenoid will
activate and the washer will operate in high spin.
SAFETY WARNING: If power is removed during this
test, the door can be opened. To prevent injury, DO
NOT put your hands inside when the tub is rotating.
10. Turn the program knob (9) clicks from the start
position. The control will signal the last error code.
Repost the error codes here.
sounds like you have a issue with your pump, I have had a simular problem with my washer and I had to call a technician out to fix the problem, if you need assistance in getting help with someone in your area to come and take a look at your problem let me know and I will help you.
I have a Kenmore 80 series mode #2289400. It will wash but will not drain and spin. I have turned the knob to a different spin cycle put it won't spin. I have drained the water out of the tub thru the drain pipe so it's not plugged. When it's ready to spin and it making no noice. Any help would be great.
Amy, there was a service flash for the lid switch on this model. The contacts inside the switch were sporatic which caused; stopping in mid cycle, wet clothes and no drain. You would have to put it in spin and have someone jiggle the wires to the lid switch to verify that this is the problem and not a timer problem. I really think it's a lid switch problem. Your part number for the new, non adjustable switch is 12001908.
