Just reset the unit then unplug it for 30 minutes..
hope this may help;
Regards,
VOTIT
click below ;
BlackAndDecker Coffee Maker Manuals
Regards,
VOTIT
Setting "Wake-Up" time;
This feature enables you to enjoy freshly brewed coffee at any pre- selected time with in 24 Hour time period. To use this feature , follow the instruction after setting the digital clock.
1. Press the program button and green light will appear indicating that the clock is ready to be programmed immediately press the "H"(Hour) button and then the "M"(Minute) button to set the program time .After a few seconds the LED clock will jump back to the regular time.
The "Wake-Up"time is stored in the electronic memory .If you want to check the "Wake-Up" time that has been programmed,simply press the programs button and the "Wake-Up"time will be displayed for a few seconds.If you wish to change the "Wake-Up" time press the program button and proceed as described in the above mentioned paragraph..
Hope this may help;
Regards,
VOTIT
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
