There could be several reasons why your Cobra camera system stopped recording:
Storage capacity: If the storage capacity of your camera system is full, it may stop recording. Check if you need to delete some old footage to free up space.
Power supply: If there was a power interruption or outage, the camera system may stop recording. Ensure that the power supply to your camera system is stable and reliable.
Camera settings: Check the camera settings to see if there are any settings that have been changed that could have caused the system to stop recording.
Camera malfunction: It is possible that there is a problem with one of the cameras in your system, causing it to stop recording. Try troubleshooting the cameras individually to see if they are functioning properly.
If your camera system started recording again after stopping, it may have been a temporary glitch. However, if the problem persists, it is recommended that you seek assistance from the manufacturer or a professional technician.
I don't believe that camera allows that. The JX600 is an automatic P&S camera. If you look around, you may find a deal on a Fuji F series camera, which has manual and semi auto controls in addition to full auto.
The F/stop isn't supposed to change when you focus. Depending on the camera, you change the f/stop by either turning the aperture ring on the lens or turning a command dial on the camera body.
no new camera is required, you have just changed the settings and it can be modified if you just calmly go through the manual given to you by the manufacturer.
HI, When you set it to A that means Aperture Priority. You will need to change your f stop. The f stops determines how fast your lens opens and closes. I can't tell you what f stop to use as it depends on what kind of lighting you are shooting your pictures in. Best wishes.
Try it on bulb, and open the f and check it is working properly the problem might be the computer inside the camera and there's no replacement spare parts, but yoou canfind another ody and swap the computer.
