Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
If it will not stay lit from a cold start, you will need a thermopile. You can check it if you have a DC meter that will test milivolts. It should be putting out between 300 and 500. If it will not stay lit after the pot gets hot, you will most likely need a high limit. Try pushing the red button below the thermostat. This will reset the high limit.
