Before we use diesel power generators, installation and connection should be carried out, installation site should be well ventilated, generator end should have enough air intake, diesel generator end should have good air outlet, so
what matters should be paid attention to for daily fuel tank installation?
1.We should select a suitable location, the location needs to be safe and fire-proof, and should be placed in a visible place, properly far from the location of the diesel generator set and smoking is strictly prohibited.
2.Special fuel tank base must be built in the tank compartment, so that the tank can be placed on it alone and the interior needs to be filled. Paving the floor with fist-sized pebbles and filling the cracks with yellow sand, which can prevent the diesel oil leaking into the sandstone when
diesel oil leakage appears in the machine room. Even if fire is currently generated, it will not burn, because it has passed through yellow sand.
3.We need to do a good job of fire control measures in the machine room, also need to equip fire extinguishers, gas masks and other items, to ensure that when such a failure occurs, it will not cause harm to our personal safety.
