Philips GoGear SA1948 (4 GB) MP3 Player Logo
Anonymous Posted on Mar 14, 2011
My player has frozen. Everything I've tried, and every button I've pressed, doesn't work. Need help!
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Mar 14, 2011
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882372
Points
4663
The firmware of your Philips GoGear SA1948 MP3 player has become corrupt.
Fix it by reflashing the system software, which you will find at the Philips website here.
  • Anonymous Mar 14, 2011
    That's cool. Done that. The only problem is when I hook up my mp3 player to my computer it tells me it's not connected.
1helpful
Hi, I have a sharp tv that recently had a yellow K and says LC-B50CF6001KB and I’ve tried everything to fix it. I doesn’t have an input button so I guessed this was source still can’t get into service menu...
1) Press Channel down and Volume Down button from LED panel a same time.
2) Page option will display.
3) Select 9/10 page by pressing up and down button.
4) EEP option will display.
5) Press Ok button.
Switch Off and Switch On from Main LED work properly
tip
How to reset forgotten password Apple Ipod Touch.
Try a soft reset and hard reset your iPod Touch if it’s frozen or not responding.
Try a soft reset first:
1. Press and hold theSleep/Wake button on the top of the unit until a red slider appears
2. Drag the slider.
3. Press and hold theSleep/Wake button until the Apple logo appears.
If a soft reset doesn’t work, try a hard reset:
Press and hold both the Sleep/Wake button and the Home button for about ten seconds, until the Apple logo appears.
on Feb 11, 2010 • Apple iPod touch
I can't get out of my recovery mode on my Archos
Is the button sticking or is it damaged
Ice dispensor doesn't work
When your power was off it probably caused some ice melting, then when power was restored it froze where it shouldn't. Try to see if there is ice freeze up where there shouldn't be any. Not talking ice cubes, just small amounts of frozen water making things stick together that shouldn't. Gently jiggle a few things. Lol. This has happened to me before. As far as I know there is not a reset button.
My ipod is disableb because my little brother kept putting in the wrong pass code and i dont know how to fix it
2. Drag the slider.
2helpful
Frozen screen
When the Sansa e260 is frozen, first try to reset the player.
How to reset the e200 series player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
When resetting does not solve the problem, a reinstallation of the
firmware should be performed.
Need more help ? Just post a comment.
6helpful
5answers
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
2answers
My screen/mp3 is frozen
Press and hold A-B button and menue button at the same time.
7answers
C150 frozen!
Try a hard reset press and hold vol + and center select button for 20 seconds. Best of Luck.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
