SOURCE: Fuji Finepix E900 freezes after 2pics, must remove batteries
I had the same problem and when I contacted Fuji they said that there was a defect in a chip that several of the name brands had used for a period of time. They had me send in mu Finepix and they repaired it for free.
SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
SOURCE: how do you charge the battery on a fuji finepix z digital camera
The battery does not charge via USB.
Place the battery into the charger, then plug the charger into a wall socket.
Refer to the section titled "Charging the Battery" in the manual.
Testimonial: "Thank You, now all I have to do is purchase a charger."
SOURCE: Fuji FinePix S5000 stuck in date/Time mode
all you have to do is undo the back, and replace Lithium battery and it should work. You will need a service manual just email me at [email protected], i will email you one
