SOURCE: My PD 6030 Wont turn on
i think you need to upgrade it
or also you could delete all the files then re-add them because there is a posibility that a corrupted file is causing it
if you tried it pls do reply to this post
thank you!
SOURCE: it wont be recognized my musix pd-6070
try uninstalling it with the add/remove hardware opt. on control panel. check hidden devices on device list to see all devices. then plug it back in after its uninstalled. If that doesnt work try using free version of real player, it has drivers for most mp3 players and will work with many more than media player 10.
SOURCE: windows media player won't allow me to sync files to my My Musix mp3 player....
This player doesn't play well with WMP-11. Try reformatting inside Windows Media Player, but this may not work. Other methods you can try:
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
