ASUS A8Fm PC Notebook Logo
Posted on Mar 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have trouble doing windows vista registration on line after re-booting my system. My labtop has OEM and original version was installed. Can please assist in the registration. My 25 character are as follows: RJMT9-M8WJ8-GCG8T-6RRHW-P7M7J
Anonymous
Level 2:
New Friend:
  • Expert 93 Answers
  • Posted on Mar 13, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
93
Questions
0
Helped
18033
Points
314
You are supposed to keep your product key as secret. :) Anyway, your licence may have expired, in that case you may need to purchase a new licence key. Also try contacting your vendor.
Anonymous
Level 3:
  • Master 1,940 Answers
Anonymous
Master
Level 3:
Answers
1940
Questions
0
Helped
954206
Points
5951
Occasionally some Windows Vista user may need to activate his or her copy of Windows Vista operating system through phone activation, such as in situation where the computer is offline without Internet access. Other possible reason to use phone to activate instead of automatic online activation is failure or facing problem to activate Vista online, and user have to fallback to alternative.
For most users, activation process normally starts with attempt to activate Vista online. Online activation is simple and effective way to activate the copy of installed Vista, and when it fails or cannot activate successfully, then user can opt to activate by phone. If you want to skip and bypass online activation and go straight to activate Vista or Windows 7 by phone (i.e. in the case of offline PC with no Internet connection, do these steps:
  1. Click on Start Menu.
  2. Type slui.exe 4 into Start Search, and then press Enter.
  3. Go to step 10.
Normal activation procedures for Windows Vista, including fallback on phone activation:
  2. Right click on Computer and then click Properties, or open the Control Panel -> System and Maintenance -> System icon.
  3. Scroll down to the Windows activation section and click on the Activate Windows now link.
  4. Click on Activate Windows online now. Note: If you have not entered a product key during installation, the wizard will ask for a genuine serial key. If you uncertain of the serial number key used, or want to change the key used, click on Change product key link.
    And, this step must fails in order to go to phone activation.
  5. If the online activation process, user can continue to attempt to activate using automated phone system by clicking on Use the automated phone system to activate option.
  6. Select your location and click on Next button when prompt to find available phone numbers for activation.
  7. Click Continue if prompted with UAC dialog box, except for those who had disabled UAC.
  8. A local phone number or nearest telephone number will be displayed on screen, together with a set of Installation ID (54 numbers in total - 6 numbers in 9 groups) generated by Windows.
  9. Call the activation phone number.
  10. The call will be answered by automated voice response (AVR) system, that asked caller to speak, or if voice recognition failed, press the phone button to enter the Installation ID listed behind "Step 2?. The numbers needed to enter is a lot (54). If you want simpler way to do it, just speak and enter anything to let automated service fails, and then wait for the call to transfer to activation operator (a real human). Sometimes, if for some reason the Installation ID entered is not accepted by the AVR, your call may be transferred to human operator too. Note: The human operator may ask for the reason that causes requirement of reactivation or activation of Vista. Just tell the truth, e.g. hardware upgrade, transferring to new PC (for non-OEM edition only) and etc.
  11. No matter who you talk to (machine or human CSO), a set of Confirmation ID numbers which consists of 48 digits (6 numbers in 8 groups) will be given if Microsoft believes that your copy of Windows Vista is genuine and legitimate. Write down the Confirmation ID.
  12. Back to Windows Vista, type in the Confirmation ID given by the phone system into the wizard boxes after the "Step 3?, and then click on Next button.
  13. The activation should be successfully done with Activation was successful window appears. Click on Close button to quit.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2helpful
3answers
Windows 7 home basic product key for Product id 00346-OEM-8992752-50258
Windows 7 Home Basic with the key you provided is an Original Equipment Manufacturer (OEM) version of Windows 7. These versions are auto-keyed/auto-activated with a BIOS check when booting to the media to install Windows.
The only times it should prompt for a product key are:
  1. Installing the OS on a different brand system other than the OED brand it was designed to be installed on.
  2. Installing Windows from inside an already running install of Windows instead of booting to the Windows media.
If this is the OEM system the OS shipped on and you are prompted for activation, flash the bios to the most current version and run the Microsoft WGA tools to clear the activation prompt.
If this is not the OEM system the media shipped with, then you can't activate it.
If you installed Windows without booting to the Media, then boot to the media and re-install Windows.
If under warranty, contact the OEM warranty service as they provide support for OEM Windows.
tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 • Computers & Internet
Product key, I have a original version but the product key is not installing it.
If you have got the original Vista along with the branded computer (OEM) it might not install with the product key available on the COA label stuck to your computer. You have to choose the right installation method.
You have to boot from the CD/ DVD and initiate installation. This process will not ask for the product key for OEM CD/DVD.
If the situation is different you need to search for the receipts of purchasing this Vista and contact Microsoft.
2helpful
2answers
I hate Vista. I want XP.
Hai,
Yea that's true Vista sucks.....XP best!
If you want to install completely with XP then as usual procedure format the system with your Windows XP CD(C:/ drive only, with FAT32 or NTFS).
I have a labtop x61 tablet which failed to boot the operating system windows vista
The best way to fix this is to insert the Windows Vista DVD that originally came with the computer. After you have the disc in, restart the computer and you should be prompted to "Press Any Key To Boot From Disc" or something along those lines...
Once you do that you will be given the option to repair Windows Vista. It will automatically scan the computer and fix any issues.
If you have a specific error message or have any trouble doing this, please let me know and I will be more then happy to further assist you!
Windows Vista registry corrupt after trying a "chkdsk /f" When trying the original Vista CD to boot it tried a re-install instead of trying to repar the problem - now I have a /Windows and /Windows.old And...
Try running chkdsk /r from command prompt in the Vista Recovery console. If you cannot access it for whatever reason, boot from a WinXP disk and press "r" at the first screen. Once you have the command line, type the chkdsk /r command. If that does not work, please post back.
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
My Acer 5100
Hi
Go to safe mode by pressing F8 on boot of windows vista and restore windows you find it on accessories>system tools....
Thanks
2answers
Downloading windows vista
You should be getting in touch with Acer support for this. I can tell you that many people are removing Vista and installing XP on to their computers because of the problems that they are having with Vista.
To properly install XP, you will have to buy a lagitimate copy so that you can register it.
If you really want to put back Vista, you should have the activation codes with your original installation software that came with the computer. If this does not work you will have to call Acer support. There may be some issues that are not generic. Acer like many of the brand names may have specific requirements.
Jerry G.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
