Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. It will be best to buy a new one, rather than trying to repair this TV.
Sometimes the setup procedure might be not right. Check it with an other code. If you wish to get more setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to
some popular model remote controls are given. Zenith TVs should synchronize with codes to RCA. Check the number of digit codes, that the TV asks. If it is a three digit one, and you are entering a four digit code, the TV won't synchronize.
do google search for that remote you should be able to get it for about $35.00. If you do not have the model of the remote search for the model number of the tv with the word remote.
Here is a link to a replacement remote for you:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=16-3350FLAT&uuid=A12731975097341&brand_pn=AXION_16-3350FLAT
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
no audio, excellent picture
