Sd means suds was detected. "Sd" is displayed when the control senses drag on
the basket. Too much soap makes the motor work harder causes it to
overheat and generally suffer a beating. The wrong soap also triggers
this. Also An item of clothing jamming the basket can trigger this
warning. The control has a program to remedy it. Filling, rinsing, and rechecking all in the name of making sure yall's clothes ain't got no soap in em. If the control cannot fix the probo after trying a bunch of times, then it declares an error has occurred and everythang comes to a screechin halt.
Cabrio Washer Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
SOURCE: e17 error code
Hi shawn833,
F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter. Also check water pressure is not too low If all these test ok you need to run a load with no clothes with 1 cup of white vinegar this will solve your issue.
Regards
R.K.
SOURCE: what does the error code Sd mean on my Maytag Epic
Hi Please accept
the solution if the issue is resolved post a comment for further assistance.
Thanks for using FixYa. Error 5d/Sd means too much detergent was used. Try the
following procedure---
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any
detergent.
This should clear the unit of the excess detergent. If still the problem
persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and
Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Thanks
Rylee
SOURCE: what does an error code
http://www.fisherpaykelparts.net/partmanuals/IWL12US.pdf
Supplementary service manual below... above is the usual one...
http://ww2.justanswer.com/uploads/thehomesmithy/2010-12-19_141627_gwl11_iwl12_iwl15_suppliment_togwl03_manual_.pdf
Hi, well this Beeping, simply indicates a "Fault" however it gives NO indication of what? It maybe a sensor, the main board, the motor? but it could be many many things unfortunately. What you need to do is either DIY troubleshoot or call a professional, it is really that simple.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/
above is a DIY help website to assist you in troubleshooting, use the manual to isolate and hopefully repair your unit.
However if you don't wish to DIY the to get the best and cheapest outcome, is to contact an F&P local or head office, and ask for a referral to an authorised service center, now when in contact here ask for a service call, however ONLY ask for a "Quote" as to costings, now when you are appraised of these then one can make up ones mind as to what to do, repair or replace?
SOURCE: What does SD error code
Hi Error
code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8
minutes and the water valves turn off. After 4 minutes the "Sd" error
will be displayed, and then 4 minutes later the F21 error code will be
displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the
drain hose and make sure it is not plugged or kinked. If the drain hose if fine
then unplug the washer and check the electrical connections at the pump and
make sure the pump is running. Check the drain pump filter for foreign objects.
To access the drain pump and filter remove the front kick panel and trace the
drain hose to the bottom of the washer, drain pump would be located there. If
you are not able to access it, then replace the back panel as well. Plug in
washer or reconnect power. If the issue is still not resolved then you would
need to replace the drain pump. Hope this helps...please post
back for further assistance. Daniel
Hi
Error
Daniel
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
