Go to a computer that is currently hooked up to internet through that device, hit the start menu, go to run, and type cmd in the field and hit enter. When the command prompt comes up, type: (ipconfig) without the parentheses and hit enter. You should see "default gateway" and a set of numbers next to it. Like: (888.888.8.8) only different numbers of course. Open up internet explorer and type those numbers in the address bar at the top where you normally put in a website's name. Once you hit enter, it should ask you for a password, the default username is usually: admin the default password is also usually: password, or a set of 0's, or admin again. If you can get past that point you should be logged onto your device and be able to change anything you want. Let me know.
