I have a 1999 Damon Challenger Motorhome that blows cool air from heater .
Check the hoses to see if each hose is warm, usually 1 is warmer than the other, that enter the heater core from the engine.
If both are warm issue is inside vehicle, possible vacuum operated valve for venting or a cable, sometimes items drop down from dash, like toys, pencils, etc that could stop the action of the vents that adjust heat.
If 1 is cold then look for a valve possibly inside engine compartment on one of the heater hose runs, either vacuum line fell off, cable fell off or valve could be defective if no heat passes.
If no valve, then chances are the heater core itself is clogged and needs to be replaced.
This is all assuming that you have proper coolant level, the thermostat is functioning correctly, and your water pump is working, those should be verified as well when inspecting your heating issue.
