There are no error codes. but my french door refrigerator is making noise when it is close. but if i open the doors the noise will go away. if i open the freezer door the noise is still there. the noise can go on for hours and it could shut off anytime it wants. i m thinking its a the bad fan? but not sure. can someone help. thanks
SOURCE: LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
SOURCE: My refrigerator is peeping every 2-3 minutes,
I called the repair department from the dealer where I bought the fridge from and they helped me.
thank you.
I have the EXACT same problem. Did you get your's resolved? What did you do?
Same exact problem as mentioned above . Please let me know what the solution is.
I have the same problem. Sounds like a fan in the back of the Freezer is not working correctly
