Question about Sanyo VPC-CG6 Digital Camera
I tried to save a video from the card and it transferred as files MPEGTEMP.000, MPEGTEMP.001 all the way up to MPEGTEMP.009. the last file contained most of the data. Is there any way I can save this video so it is watchable?
    Dedicated:
    Visited the website for 20 consecutive days.
  • 724 Answers
I'm not sure if your camera requires special procedure to export files or maybe dedicated video player. To try if are files using any standard codec. Make copy of your MPEGTEMP.009 file. Rename copy to "test.mpg" try to play that file .you may want to download free vlc player.it plays almost everything.
Posted on Mar 10, 2018
2 Suggested Answers
6ya staff
SOURCE:
lallulallu
SOURCE: "FILE CONTAINS NO IMAGE DATA"
It may be of your new SD card. Try with another SD card. It may not show you File contains No Image Data. -Lalith
Posted on Jan 02, 2011
How do I copy a video file from my cell phone's device memory to a micro SD card?
Your video is stored on your phone's micro SD card already. Remove the micro SD card in your phone and mount it in your computer, Ipad or tablet. You may need an adapter. Once you have removed and stored the file you can transfer it to any other device or SD card or manipulate the video file in your computer. Or you can try a direct USB connection from your phone to a computer. May need an adapter cord for that.
All else fails - open a free account with Dropbox and upload your video file from the phone. Store it there and distribute as you see fit. Sometimes you can send a large file with a text message, also.
Aug 02, 2015 | Samsung GALAXY S4
If I get a new Lowrance GPS, can I use my SD card from my ifinder Hunt in the new device and use all my saved points?
First use "add gps" and add the original unit and the H20
use "receive from gps" to call in the original waypoint file from your sd card
use "send to gps" to save the new waypoint file to the sd card
remember that the original gps file may contain more waypoints than the H20 can hold so you may have to delete some waypoints from the file while in EasyGPS
if this is not clear enough, let me know and I will try again. I use the program all the time.
I just realized I left something out. EASYgps does not like the Lowrance HDS File version so an extra step is required if you are transferring files from an HDS to an IFinder. Save your HDS waypoints as Version 3 to the SD card and EASYgps will accept them
Oct 21, 2013 | Lowrance iFINDER GPS
I AM NOT ABLE TO TRANSFER VIDEOS TO PC and i have lost the CD
Is the files are saved on the memory stick?
You can transfer videos by removing the memory stick and plugging it to a memory card reader for you to transfer files from memory card to your PC.
thanks.
regards,
longgee
Dec 28, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
I can't save files or data directly to memory card
Samsung s3310 cannot import files to memory card directly,When we are transferring through Bluetooth.When we are transferring files through Bluetooth,it stores in default to phone memory and this memory cannot be changed to memory card memory.
There is one way to transfer large files with 500megabytes size through compression of file and splitting up to many sizes.We can use any software for compression and splitting up."ERROR MESSAGE:memory is full" can be avoided through this above way.
May 12, 2010 | Samsung Star GT-S5233 Cell Phone
I wanted to check the amount of storage left on my zoom h4n sd card. I went into the sd card file via the zoom h4n menu and it asked me if I wanted to format the sd card. I tried to select 'no' but the...
You may try some recovery software to rescue the files on your handy recorder, here are some for your option.
Photo Video Music Recovery (for Windows)
Photo Video Music Recovery for Mac
Both programs can also recover video and music files.
Note: Before your files are recovered, do not attempt to save more files to the recorder in case the original files(your recordings) are overwritten.
Apr 19, 2010 | Zoom H4 Handy Recorder
How to transfer long video from Canon PowerShot SD870 IS to comp?
Using a card reader is not a solution. It's a work-around. IT dos not solve the fact that many canon cameras have this problem with large files.
It is useless that you cannot copy it without using a card reader. Everybody should be able to transfer their files from camera to any computer anywhere, without having to bring anything but the usb cable.
Apr 11, 2010 | Canon PowerShot SD870 IS Digital Camera
I DON'T KNOW HOW TO TRANSFER FOTOS AND VIDEO TO MY CRUZER MICRO 2GB
There are several ways to do it. Try this.
Go to my Computer and select the stick drive by double clicking the icon (removable drive, e? f? g?, depending what other drives you have on your machine) This should open a window for that drive showing its contents.
Now go to the folder that contains the files you want to back up. Right click the file you want to back up and choose Copy. Go back to the window for the stick drive and left click in the window, then right click and choose paste.
Your file should now be copied to the memory stick.
If you want to save several files click on the first one, hold down the Shift key and click on the last one in the folder and they will all be selected - then right click and select Copy. Then do as abaove to save to the memory stick.
Mar 10, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
How do i transfer a saved file from usb to my memory card ?
you can transfer save files from flashdrives to memory cards by using Action Replay Max disc or similar similar devices
you need to buy it
Aug 22, 2009 | Sony PlayStation 2 (PS2) Console
Files can not be received on storage card on HTC S710
try moving all recieved files to d card, also if d file size exceeds d size of available memory, it aint gonna work..
Last resort, use d phone cable to transfer heavy files wit a PC
May 01, 2009 | HTC S710 Smartphone
Platstation-2 save files transfer to memory card
interesting... call sony they will have better information but since its a china model it might not read the flashdrive
May 03, 2008 | Sony PlayStation 2 (PS2) Console
Sanyo VPC-CG6 Digital Camera Logo
426 people viewed this question
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
