Follow this guide
http://howto.wired.com/wiki/Set_Up_Port_Forwarding_on_Your_Xbox_360
setup your xbox with a static ip address.
setup your router with the following ports forward to the ip address you gave your xbox
Since you've already assigned a specific address to your Xbox, you can now open up the individual ports of this address. According to Microsoft, the ports that require forwarding are UDP 88, UDP 3074, and TCP 3074. If your router requests a range, just be sure that the numbers entered span this range (i.e., 87-89 for the first port, 3073-3075 for the second, and so on).
