How to Unlock Black Berry 9530
Just Go to Unlock blackberry Phone How to Unlock blackberry Phone
Make your selection like model->country->network-> Mail ID and update IMEI by login to the unlockninja portal
code will be delivered with in 1-2 business days How to use the unlock code
How to Unlock the ZTE MF60
1) Insert a non compatible SIM card to your locked ZTE Cell Phone,
2) Phone will prompt for Unlock Code (NP Code),
3) Enter the Unlock Code you received.
Hello. Begin by removing the battery from the black berry for 5 minutes. This will reset your black berry to factory settings and may well solve your problem. If it does not, you will have to take your blackberry into a phone store. Joe
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need: 1. Computer 2. Nokia N70 3. Black Berry phone 4. Nokia PC Suite CD 5. Black Berry sync software
How: 1. Install the Nokia PC suite to the computer. 2. Connect the Nokia N70 to the computer. 3. Export all the Contacts from Nokia N70 to your computer (refer to the manual) 4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry. 5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
go to call log and open it click with ball and choose full menu go to options and change your options also if you can take it to your provider store they will help you set it up.
i would call black berry tech support . Some blackberry need a soc or code added to recieve video and pic mail and sometime certain data from one server to another is not compatible . Well hopefully its just adding the code and it all pans out for you
you have to take both simcards to a nextel shop and they can switch all your contacts to the new one and they can also send any ringtones that you have as well
