On your PC if you go into Start/Settings/Control panel/Sounds and Audio devices, under Hardware tab/Audio codecs, click Properties, you'll see the driver listed as "Fraunhofer IIS MPEG Layer-3 codec (decode only)". This confirms that the wrong driver is installed.
Something you installed, probably to burn CDs, installed a playback-only version of the driver. The driver is l3codeca.acm, which is replaced by the playback-only version l3codecx.acm.
You need to edit the Registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32.
Locate the item named msacm.l3acm.
Its value should be changed from l3codecx.acm to
l3codeca.acm.
Note that you might have to use the full path name thus:
C:\WINDOWS\system32\l3codeca.acm
For its name to appear properly in the Audio codecs list.
If that's not your problem, and you want to tranfer files to and from Mob/PC.
Go here to learn more:
http://www.knowyourmobile.com/motorola/motorolarazrv3i/motorolarazrv3iuserguides/167/backing_up_your_motorola_v3i_to_a_pc_by_bluetooth_or_sync.html
