Optoma H30 Multimedia Projector Logo
Anonymous Posted on Mar 10, 2011
Optoma H30 -- When turning on projector the green light on power button blinks and the projector sounds like it is going through a cycle....after the cycle the lamp light comes on and nothing comes on the screen. I thought it may be a blown lamp so I replaced and have the same problem. Can you help?
Anonymous
Level 2:
  • Expert 442 Answers
  • Posted on Mar 11, 2011
Anonymous
Expert
Level 2:
Answers
442
Questions
Helped
176868
Points
703
If the lamp light is orange then the lamp ballast circuit or power to it is no good.
I presume the lamp is not on at all, and it's not the hide function that is stopping the light coming out.
2answers
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Optoma EP781
if all lamp are red, and no light on, It is power supply issue,
you need to replace power supply, it will be ok.
you can send me your old power supply photos, perhaps i have same parts,
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
I have an optima EP 739 projector and I just replaced a bulb in it but it does not come on just green light whats up Any input would be appreciated
if the fans come on and the lamp doesn't, it's the ballast or the colorwheel. if no fans either, it's the power supply. also, did you reset the lamp timer?
I have optoma dv10 projector the dvd is playing but there is green flickering lines over the picture can anyone help
Hi
Try to change the cable from source to your projector. or make sure everything is connected properly.
Hope this help
Projector will not turn on no fan no light
Hi!
Here is a link to the "Troubleshooting" part of the manual to Optoma H56 Projector. Hope it will help!
Troubleshooting Optoma 56 User Manual Page 27 of 32
3helpful
3answers
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
1helpful
H30 Crashing
The only thing I can think would be that the projector is heating up because the air filters are clogged.
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
