. Very carefully , while looking at your door seal at the top of the door , peel it up from underneath , or from the bottom of the seal upwards and you should see the screws or retainer strip . If there is no screws or retainer , then the seal has a lip on the center of its base that runs all the way around the door seal. You won't be able to see it until you pull the seal away from the door . Start at the corner and pull the seal straight out away from the door and you'll see the lip which locks into a groove in the door self . Only do this once you have made sure there are no screws or retainer strips used . Once you pull the seal completely off the door , clean the groove with warm soapy water . Also , when installing the new seal , apply some warm soapy water to the lip on the new seal to aid you in pressing it back into the door . Here again , start at the corner and take your time . Be careful not to stretch the door seal as you install it . Good luck
