Question about Sanyo VPC-E760 Digital Camera
When a take the photographs outdoor they doesn't come out properly: that is they are foggy and fuzzy
  • 2,517 Answers
Hi there please clean the Sensor of the camera and lens glass. then try . After that if you same same problem then follow this.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Posted on Mar 10, 2011
Anonymous
SOURCE:
I have the quantaray lens ld 70-300mm. Was working fine until one day. When I look through it everything looks slightly foggy. Adjusting it doesn't help. Cleaned the outside lens. Would like to kn
Yes, the lens can be disassembled and cleaned. But before you think about doing so, think about this. Do you have a lens collimator and other equipment necessary to ensure proper alignment on reassembly? If you don't, please leave inside cleaning to a trained professional.
Dec 05, 2012 | Cameras
Tip
Use a polarizing filter when photographing the great outdoor.
A polarizing clarify gives you added adverse and richer, warmer tones back taking outdoor photographs. A polarizing clarify can be rotated to accord the adapted effect. If you accept polarized sunglasses, try captivation the sunglasses in advanced of your face and attending through one of the lenses. Rotate the sunglasses and apprehension the aberration in the tones and adverse of your surroundings. This is what you can accomplish with a polarizing filter. If you don't accept a filter, you can use your polarized sunglasses - aloof authority one of the lenses as abutting as accessible to your camera lens. Oh - accomplish abiding your sunglasses are clean!
on Jan 07, 2011 | Cameras
My Sony Cyber-shot DSC-H9 has a problem when i'am using it outdoor, sunlight .Can shoot a picture, but screen dosen't display the area being photographed.
you must read the owner manual, section troubleshooting for indicate what is wrong. and fix it. Otherwise you must to the repair shop for fix it.
Normally the LCD is faulty, and need replace it.
God bless you
Sep 22, 2012 | Sony Cyber-shot DSC-H9 Digital Camera
Good evening. I have a camera CoolPix S10 which takes beautiful photos. But when I photograph an orignal oil painting, the photos are kind of foggy and the colors are dull. What kind of settings do I...
If you are taking the photo inside with artificial lighting then this will affect the colors.
Try taking the photo of the painting with outside lighting.
Apr 10, 2012 | Nikon COOLPIX S10 Digital Camera
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
My outdoor pictures are very very pale, almost white with stripes across the entire photograph
Too much bright when you taken the picture, try to turn off the flash light when capture outdoor or in bright room.
Hope this help.
Mar 09, 2011 | Fuji FinePix F10 Digital Camera
All my windows get foggy
If Your Fan is operating properly, along with Your defroster Meaning Your A.C. Pump is charged and engaging, I would have to take a look at Your heater-core to see if it may be leaking on to Your floor on the passenger side. Therefore causing more moisture in the car than can be evaperated under normal conditions... Hope this may Help!
Feb 17, 2009 | 1998 Honda Accord
Outdoors pictures too bright
I think your ISO setting is very high or is in default.
Please shift it 100 whent you thaking outdoor snaps in daylight or normal indoor light. It will help you to produce a better photograph.
Best wishes.
Nov 30, 2008 | Canon PowerShot A420 Digital Camera
Fuzzy bright stars with my Celestron CPC 1100 XLT
The image shows that the optics are not centered properly. The secondary may be tilted slightly to the 2 o'clock position. When not centered, a focused star will have an astigmatic shape, and not come to a full focus. Also check the mirror and corrector plate for dewing, that will also affect the views.
Nov 02, 2008 | Optics
Sanyo VPC-E760 Digital Camera Logo
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
