I went to change the bulb in my tv after i was done i turned it on i had picture and sound turn it off for like 1 hour turn it on had picture but no sound please help me with this problem
i was playing wii and the tv went to lines so i turned it off now when you go into the ausio menu and try to turn the sound on it wont come on even if you use the remote and we just got the tv. help!!i was playing wii and the tv went to lines so i turned it off now when you go into the ausio menu and try to turn the sound on it wont come on even if you use the remote and we just got the tv. help!!
same problem. JVC 27" bought from a friend. Had sound at their house. no sound at my house. Picture ok. Anybody know how to get the sound back?same problem. JVC 27" bought from a friend. Had sound at their house. no sound at my house. Picture ok. Anybody know how to get the sound back?
Have you done a bulb time reset; before and after the bulb replacement? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Try a "hard reset" first by unplugging the set for 30 seconds. and if no help, you may have a problem with the SMPS power supply, it might have a bad capacitor or two by now. Worth repair if engine is good compared to a flat panel.
Probally the Ballast board have problems,if the safety switch problems,u should not have a picture at all in the first place.Now,the tv turn on?U hearing alot of clicking?Yes,the Ballast board is dead,it not igniting the projection lamp anymore.
The tv projection lamp has not been change in this tv the last 1/1/2 or 2 years and been on an watches 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
The life estimate for a bulb is about 5000 hours, and if the bulb is dieing before that is very obvious you have another issue on the TV
That Could be a temperature problem, like a cooling system is failing (usually the is two fan around that) or a lot of dust in the cooling system. another one could be temp sensor also maybe failing and is not sensing high temperatures and is no turning off the TV
Also make sure you have enough ventilation in the back of the TV
Hope this give you a better idea of the problem thanks
The lamp is turned on by a high voltage ballast, very similar to the ones in your fluorsecent light fixtures. Your ballast is starting to fail. You should have your TV serviced by a JVC authorized service center because they have the training to deal with this issue. Waiting until it fails could very likely cause more servere damage especially if it fails shorted then the power supply will need to be replaced as well.
It may be lamp, Look at the lamp and see if there is any discoloration inside, but do not touch the lamp glass. The oils from your hand will heat up and blow the lamp. The lamp part# for your model is TS-CL110u. Hope this helps.
I have no sound on my 52 inch JVC TV, I have a picture but no sound
