Instruction manual which came with Umbro junior sports digital watch is for an analogue watch! Where can I find the correct manual online please? Kind regards.
Re: Instruction manual which came with Umbro junior...
Go to http://www.nike.com/timing/ and select your watch range from the drop down menu that is revealed when you click on "find a manual for your model"
Question edited for clarity.
Question moved to Watches from Sewing Machines.
Here is every Sekonda Manual. Look for a 4 number code on the back. Normally there is a button combination that moves the hands fast or a click at a time like an alarm clock or timer.
Pull the crown to first click. Turning one way changes DATE, turning the other way changes DAY. Fully pulled changes the TIME. (Based on my Rolex Submariner)
Google
make model manual
They are all out there. Here a few for your mystery watch. Number one tip, FULL Make and Model in every question please.
Manuals · Case numbers are classified into the following two types: · How to find Manuals of your watch · What is Movement number? · Notes for the movement ...
Watch Manual Lookup. We have developed a program to help you more easily get to the correct instruction manual for your watch. All you need to do is enter the ...
Push and hold the reset button on the bottom right of the watch and then push the mode button on the bottom left. When you push the mode button, all the days of thge week should no longer be illuminated. This is the same to turn the beep on, only you need to see the days of the week on not off.
Digital time must be set using pushbuttons on watch case sides. One of them is for MODE, another for SETTINGS. Mode button usually must be held pushed in for a while to start to work and the digits should start to flash - only then you can start to reset your digital watch using another (settings) button. Use small steal pin to push these buttons. If nothing happens, you will have to consult your nearest watch repairer as in this case there is a mechanical or electronical fault. Rating is very appreciated.
hello, my watch is bijoux terner sport R0607L here is scanned manual: http://i280.photobucket.com/albums/kk197/somber_glass/scan0003.jpg?t=1226240017 I hope it would be useful :)
