Sony VAIO VGN-FS840/W Notebook Logo
Anonymous Posted on Mar 09, 2011
I am trying to get a Sony Vaio FS840/W laptop to connect to an LCD TV using a VGA to HDMI cable but it does not display anything on the TV. Is this the right cable? Or does the computer not support this? Help :)
  • Louie Laforteza Mar 09, 2011
    Is the HDMI port on the LCD TV is the input. Because most of it are output.
    Check the port for any input.
vimal
Level 3:
  • Master 340 Answers
  • Posted on Mar 09, 2011
vimal
Master
Level 3:
Answers
340
Questions
0
Helped
68674
Points
1121
You need a converter to convert the VGA analog to HDMI digital signal
Connecting sony viao to panasonic viera
try connecting through HDMI port on your laptop or use a VGA to HDMI converter or Connect with Wifi
2answers
Does the Sony VGN SF790 support hdmi cables? I would like to connect to my Sony Bravia TV
Hi.
No I'm afraid not. It only supports VGA out. If your TV supports a PC input then a male to male VGA cable will do. VGA does not support audio so you will also need an audio lead to connect to the TV too.
Regards.
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
VAIO FW Series is laptop that I am using. I have damaged the LCD of laptop and I want to use Television LCD as its secondary display. When I connect HDMI Cable or Monitor cable from my Sony Bravia TV, I am...
There is a button that you have to push when you use an external monitor - see if you can find reference to it in the manual or go to the web site for further assistance.
You may even be able to google for the info.
1helpful
2answers
Connect Sony Vaio Laptop to DVI on Sony LCD Projection TV
try to lower the resolution of the display, to know how please visit the following link:
https://www.microsoft.com/windowsxp/using/accessibility/screenresolution.mspx
< Please Rate :) >
2answers
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
2answers
Sony vaio geforce driver
Try to reinstall the driver.
You can get it from www.nvidia.com
If worse comes to worse, you could always reinstall windows.
1helpful
3answers
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
