Your battery is losing voltage too quick. It has probably developed a
'memory'. Dyson claims that their handheld has the best suction out of
all the handhelds out there. In order to maintain that claim the circuit
board will shut off power to the motor when the voltage drops below
adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so
it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
