My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Http://www.whitegoodshelp.co.uk/wordpress/samsung-rs21-and-rs60-range-fridge-freezers-recall-potential-fire-risk/
Fridgefreezer making a rattling noise, freezer keeps defrosting food
My freezer will not freeze and my ice maker will not work. Ithink it is the same problem that cathy had. I will check and post again if it works.
Thanks,
Chanda
I have the same problem
Samsung cool and cool
how do you change the tempreture
temperature flashes and is slowly increasing
