Its possible your set screw has come out. If you can find the holes to line it up Just keep turning the handle till you see a hole on the inside and get a screw to go into it. Really not sure if this will repair it without seeing it.You may need a bright flash light to see this. If there is still a screw in the handle its possible it may have broken off and needs removing to find the hole on the inside.
SOURCE: my brother inlaw got a minkota 40ta all terraine
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
SOURCE: i cant seem to figure out how to take my prop off
I had the same problem tonight. I wound up getting it off by appling a diagional pressure to the prop. That held the shaft screw. Then my Dad turned the wing nut with a neddle nose pliars conter clockwise and it came right off.
My problem and probably yours too is once inside there is a pin holding the prop to the shaft that was broken. I don't know how to get the new pin back in since it is inside the prop with no access from the outside.
SOURCE: Trolling motor stays on same speed no matter where
I just recently had a simialr problem. No speed control and motor only ran at 100. I talked to the minn kota tech rep and sent him my control board and he said it had a bad potentiometer...however, I had to buy a control board to fix the problem ($215). Hate to say it but sounds like you may need a new control board.
