Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
My laptop have broadcom 802.11 g adapter. but IBSS 54g(tm) mode have 802.11b/ 54g auto/54g performence only. so that, my laptop cannot access all access point. how can i solve this?
    Master:
  • 346 Answers
Greetings - Let's go over the settings in your router:
1) On the Home menu screen go to wireless in the left column 2) Wireless band should be setup as 802.11g 3) Mode should say access point 4) SSID should have a name - should also be the same name used on the laptop 5) SSID broadcast should be enabled 6) ***Important - For now set Authentication to open system. Make sure that is how your laptop WIFI card is setup. You can setup security after you get the two connected 7) Super G mode should be disabled 6) Move one tab on top over to advanced make sure data rate is auto
Try those settings (making sure the laptop settings match) and you should be able to get connected. If not, copy this text and return here and paste in into another request for help and someone will take you the rest of the way.
Good Luck, Mikeywaf
Posted on Mar 08, 2011
6ya staff
SOURCE:
Im using lenovo G450 model no- 2949 BAQ, i want to know is Wifi is available in this system and how can i install driver and from where
Yes, it does have an 11b/g wireless4, Mini PCI Express Adapter with an Broadcom BCM4312 chipset.
Get the driver from here
http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=370748
Apr 18, 2011 | Computers & Internet
My iphone shows only white screen when i try to power up
hi,
try this solution...
1. Put phone into Recovery mode (NOT DFU)
While the phone is off, hold down the Home button and immediatly plug it into your computer. Or else.
2. From a command prompt (Start>Run>"cmd"), change to the directory where you extracted irecovery, and enter irecovery -s followed by:
1. setenv boot-args 2
2. setenv auto-boot false
3. saveenv
4. /exit
Keep this window open for use later on!
3. Run greenpois0n - it will guide you to enter DFU mode, then it will stop on a white screen after you click "Jailbreak".
It should say "Jailbreak Complete!" and NOT "Jailbreak Failed!" next to the progressbar at the bottom.
4. Extract the iBSS from your custom PwnageTool image (firmware.ispw/Firmware /dfu/iBSS.BoardID.RELEASE.dfu) into your irecovery folder.
You can use WinRAR or another ZIP extractor to do this. IPSW files are really just ZIP files!
5. At a command prompt: irecovery -f iBSS
iBSS should be replaced with the name of the iBSS that you just extracted from the pwnagetool image - ie iBSS.n88ap.RELEASE.dfu
6. At a command prompt: irecovery -s
1. setenv boot-args 0
2. saveenv
3. go image decrypt 0x41000000
4. go jump 0x41000040
5. /exit
At the "go jump" point your device should appear to reboot. Whether it goes back to a white screen or shows the Connect to iTunes screen depends on the firmware image used.
7. Restore your PwnageTool cooked or CFW firmware from iTunes.
Feb 03, 2011 | Apple iPhone 3GS Black (16 GB)
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
Belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
Oct 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Net Adapter Not installed
follow this link to download your driver ---
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=4486&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
download and install
if you still have problems let me know.
if it works please mark this thread as fixed :)
Dec 26, 2008 | Computers & Internet
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
http://support.acer-euro.com/drivers/notebook/as_4310.html
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
What is 54g-LRS mode?
In some cases, older 802.11b clients may not be compatible with 54g wireless. These adapters tend to be of lesser design or use older drivers or technology. 54g-LRS (Limited Rate Support) allows these clients to be compatible with the newer 54g technology. Switching to this mode can solve problems that sometimes occur with these clients. If you suspect that you are using a client adapter that falls into this category of adapters, first check with the adapter vendor to see if there is a driver update. If there is no driver update available, switching to 54g-LRS mode may fix your problem. Please note that switching to 54g-LRS mode may decrease 54g performance. It is not recommended you use this mode unless you have a very specific reason to do so. This mode exists only to solve unique problems that may occur with some 802.11b client adapters and is NOT necessary for interoperability of 54g and 802.11b standards.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
What is 54g?
54g is Broadcom's maximum performance implementation of the draft specification for IEEE 802.11g wireless networks. This technology is expected to quickly become the next mainstream wireless LAN technology because it works faster and farther, is backward compatible with 802.11b and is affordable. Authorized products displaying the 54g logo use Broadcom's 54g wireless LAN chipset and ensures that products are designed to be completely interoperable at maximum performance with other 54g products and are compatible with the draft IEEE 802.11g specification.
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
793 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
