1) You posted under Bosch tankless water heater.
There should be a nameplate on front of unit or located where you can see it.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
2) Replacing water valve probably loosened build-up inside pipe that lodged in water heater or inside elbow just beneath tankless unit.
If water flow is stopped or slowed, tankless will not operate.
3) Remove pipes and see if clog can be flushed.
4) Also U-tupe search "delime tankless water heater" and technique used for deliming will be good way to clear out tankless clog and sediment.
Your tankless should be delimed each year anyway.
5) Read your manual cover to cover, and see words 'troubleshoot' and 'maintenance' are used throughout manual. Get acquainted with your water heater and manual, because tankless are maintenance heavy, especially if conditions are not optimal and as unit ages.
6) All costs are energy. Install tank type water heater for ez do-it-yourself repairs and maintenance.
Tank type work under all types of adverse conditions and water pressures and water conditions, and even withstand sediment build-up for several years. Of course tank-type pipes can clog too.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
