I just upgraded my cell phone to a Sony Ericson Walkman W580i phone. I want to pair it with my Motorola Bluetooth headset N136. I have misplaced the instruction manual - can you help me?
I had the same problem but I just got mine paired. The N136 is the same as the HS 850. With the phone fully charged and closed (off) hold down the call button until the blue light comes on. Open the microphone. If the blue light stays on, you are in pairing mode.
I had to do this many times before I could get the blue light to stay on while ( and after) I opened the micriphone.
I hope this works.I had the same problem but I just got mine paired. The N136 is the same as the HS 850. With the phone fully charged and closed (off) hold down the call button until the blue light comes on. Open the microphone. If the blue light stays on, you are in pairing mode.
I hope this works.
AnonymousNov 02, 2008
i can't get my bluetooth to hook up to my phoe!!!i can't get my bluetooth to hook up to my phoe!!!
AnonymousJan 02, 2009
Thank you..that worked..it took 4x but it WORKED!!!!!!Thank you..that worked..it took 4x but it WORKED!!!!!!
AnonymousJan 16, 2009
Class i was trying to pair mine with my ps3 it worked no pro. thank you so muchClass i was trying to pair mine with my ps3 it worked no pro. thank you so much
AnonymousFeb 01, 2009
Worked!! Took more than 5x to get the blue light to stay on but when it finally did I was able to pair. Aloha
did you ever get the manual. If so, could you send it to me at [email protected]did you ever get the manual. If so, could you send it to me at [email protected]
You can't post conmments that contain an email address.
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
The Motorola N136 headset, which has been updated as the nearly identical HS850, gives cell and smartphone users wireless hands-free usage with Bluetooth ...
Hold down the answer call button on the bluetooth headset until the
light is solid (not flashing). When the PS3 detects your headset, it'll
ask for a pass. The pass should be "0000" (four zeros).
follow the steps below: • Setting the headset into pairing mode 1) Ensure the headset is fully charged 2) The headset must be switch off 3) Press and hold the on button for +- 8 seconds until the light flashes red-blue 4) The headset is now in pairing mode • Searching for the headset on the phone 1) Go to “settings” or “connections” 2) Select Bluetooth, then options 3) Select Devices and click add 4) The phone should search for any available Bluetooth devices and display what was found 5) Select the Motorola device and click add 6) You will be required to enter in a pass code which is standard ‘0000’ 7) If successful then the headset will start flashing BLUE every few seconds. • The headset is now paired with the phone
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual:
http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
go into bluetooth menu and get phone to search for the headset, have the headset turned on, and make sure it is in pairing mode. The instructions should tell you how to do this.
I lost the manual for my Motorola N136 Bluetooth,
my address
[email protected]
Thank You For Your Help
I hope this works.
Aloha
what is the code for the ps3
i got the head set with no manual
