Re: Cannot install AIM. I keep getting Error Code:...
Aim is so 1990 use http://www.trillian.im/ it rocks have all of your chat programs in one program.
Its kinda of a work around
But hope this helps I love the program let me know what you think best of luck.
Question edited for a lot more clarity.
Question moved from Miscellaneous.
"Error 1935" indicates that there is a problem with the Microsoft Visual C++ Redistributable package, which is required by MATLAB. The error typically means that the package failed to install properly.
Soft reset disconneting the negative battery cable few minutes; if the code come back again, its possible that you have some problem with the sensor, wires or harnesses connections.
Keep in mind that sometimes will need OBD scanner tool to reset or delete all stored codes.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Make sure you have media player 11 If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this. Download recovery tool off creative's website. go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them Also told Microsoft hotfix causes this problem try uninstalling the last hotfix If that doesn't fix it trythe USB cable
