I noticed tonight as I was loading it that there was water at the bottom of the dishwasher. I also noticed that the dail was in the middle of the cycle. I removed the water and tried to start the dishwasher, but it didn't turn on and the door doesn't seam to be locking.
What can i check before I call a repair man.
First check your circuit breaker to make sure it didn't trip, if that is good, turn it off and take the 2 mounting screws usually at top of the dishwasher going into the counter top and slide it out. Then check the connection where the line comes in and connects to the power on the dishwasher, they are usually connected with wire nuts. Make sure connection is good.
SOURCE: Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
SOURCE: Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of plastic.no eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard somthing.im afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off ,once.you can do it.ps you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
SOURCE: Jenn-air Dishwasher won't drain water from base
This happened to me after installation. they had installed a one way valve backwards in the drain line and had to reverse it.
SOURCE: Water in bottom of dishwasher
The emptying valve is probably partially blocked with a piece of debris or bone. It can be cleared manually usually if you can get at it with a pair of needle nose pliers or tweezers.
SOURCE: leaking
this is a huge problem for you. when you have a leak coming from the bottom of the dishwasher the machine will have to come out. but first check the door gasket to make sure the leak is not coming from there.
Depending on the brand this answer may notr work. I know on the Asko there is a float valve on the bottom tray. If you tip your machine backwards you may be able to drain this water away. This helped. Good luck.
