Microsoft Windows XP Professional Logo
Posted on Mar 07, 2011
I have dvd ram drive , so can i get dvd rom on my windows Xp professional?
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
4368
Points
23
Yes, it should support it, as long as you have a dvd drive in your computer to read the discs.
DVD rom, is just a regular dvd, DVD ram is a software configuration in windows, see below for more info on DVD ram:
http://www.mytechguide.com/26/using-dvd-ram-disc-under-windows-xp/
Thanks
Except_handler4_common msvcrt.dll xp download
Option (1)
To resolve this issue, use the Windows XP Recovery Console to replace the Msvcrt.dll file with the original version. To do this, follow these steps:
  1. Insert your Windows XP CD-ROM into the computer's CD-ROM drive or DVD-ROM drive, and then restart your computer from the CD-ROM.
    NOTE: Some computers may require that you modify the basic input/output system (BIOS) settings before you can start the computer from a CD-ROM. For information about how to modify BIOS, see your computer documentation.
  2. At the Welcome to Setup screen, press R to start the Recovery Console.
  3. Press the number key that corresponds to the installation that you want to repair, and then press ENTER.
  4. Type the Administrator password, and then press ENTER.
  5. With the Windows XP CD-ROM still in the CD-ROM drive or DVD-ROM drive, type the following commands, pressing ENTER after each command:
    • cd system32
    • ren msvcrt.dll msvcrt.old
    • CD-ROM_or_DVD-ROM_Drive_Letter:
    • cd \i386
    • expand msvcrt.dl_ BootDriveLetter:\windows\system32
    • exit
    NOTE: BootDriveLetter refers to the drive letter of the boot drive. In other words, it refers to the drive where the Windows folder is located, which is probably drive C. CD-ROM_or_DVD-ROM_Drive_Letter refers to the drive letter of the CD-ROM or the drive letter of the DVD-ROM drive. The CD-ROM drive or the DVD-ROM drive are frequently located in drive D.
Option (2)
Fix the registry issue with ADV Tweaks Suite Free.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
1helpful
Ms 7050 motherboard drivers download
The makers of the motherboard should have them.
Says my system is not suported
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE Windows
  • OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
  • CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
  • OS: OS X 10.4.11
  • CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE Windows
  • CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
  • OS: OS X 10.5.5 or greater
  • CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
What my computer requirment tel me sir
The minimum hardware requirements for Windows XP Professional are
Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
At least 64 megabytes (MB) of RAM (128 MB is recommended)
At least 1.5 gigabytes (GB) of available space on the hard disk
CD-ROM or DVD-ROM drive
Keyboard and a Microsoft Mouse or some other compatible pointing device
Video adapter and monitor with Super VGA (800 x 600) or higher resolution
Sound card
Speakers or headphones(If needed)
Hope the above information will be helpful to you.
Thanks.
1helpful
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    1helpful
    2answers
    HI i HAVE A DVD DRIVE AND THE ONLY DETAILS ARE GH40N LGE DMGH22LS40 i AM TRYING TO IDENTIFY THIS DRIVE ANY IDEAS?
    • Warranty Terms - Labor 1 year limited
    • Product Height 1.6"
    • Product Width 5.7"
    • Product Weight 1.8 lbs.
    • Product Depth 6.5"
    • Internal or External Internal
    • Overall Maximum Write Speed 22x
    • Maximum Write Speed 16x DVD+R DL; 12x DVD-R DL; 22x DVD+R; 22x DVD-R; 12x DVD-RAM; 48x CD-R
    • Maximum Rewrite Speed 8x DVD+RW; 6x DVD-RW; 32x CD-RW
    • Maximum Read Speed 16x DVD-ROM; 48x CD-ROM
    • Interface Slot/Connection Port Serial ATA
    • Cache Buffer 2MB
    • System Requirements Windows 2000 Professional, ME, XP Home, XP Professional, Vista
    • Additional System Requirements Intel® Pentium® III 1.0GHz; 256MB RAM; 20GB free hard drive space; 64MB video memory
    • Average Access Time 140 ms DVD; 120 ms CD
    I hope this helps you out
    Can't read dvd ram disk
    Well not all DVD Rom's are compatible for DVD Ram. Other problem would be the formatting. Windows XP Home and Professional can only write directly to FAT32-formatted DVD-RAM discs. For UDF-formatted discs, which are considered faster, compatible device drivers or software such as InCD or DLA are required. Windows Vista can natively access and write to both FAT32 and UDF-formatted DVD-RAM discs, however Windows Vista uses its own version of the UDF format giving compatibility problems. Vista also has issues with XP formatted FAT32 discs as Vista uses the CPRM features. Even though it is possible to use any file system one likes, only very few perform well on DVD-RAM. This is because some file systems frequently over-write data on the disc and the table of contents is contained at the start of the disc.
    Hp invent p dvd940i does not see dvd disk
    1. check your system meets the requirements for your device:
    • Minimum system requirements: 800 MHz Intel® Pentium® III
    processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
    equivalent recommended (Actual drive performance depends on PC
    configuration)
    • 128 MB RAM (256 MB RAM recommended for video editing)
    • 1024 x 768 video resolution with a minimum of 16-bit color required
    for DVD authoring and editing
    • Video capture: IEEE 1394 interface or analog video capture device
    required
    • Minimum hard disk space requirements: 1 GB free for included
    software installation, 10 GB free for DVD video disc creation (18 GB
    free for double layer). Internet connectivity recommended for software
    updates
    • Operating system compatibility: Microsoft Windows XP/2000
    Professional SP4, Windows XP Professional x64 edition, and
    Windows Server 2003
    2. Have you install the sowftware that came with your device?
    3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
    a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
    4. check the removable media is in fact compatible with your drive: this is the compatibility list
    • Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
    DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
    LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
    double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
    media not supported)
    • Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
    DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-Video, 4.7 GB
    single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
    single-sided/5.2 GB double-sided media not supported), CD-R,
    CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
    CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
    Photo-CD (single and multi-session), VCD, CD-Text
    data taken from http://h20426.www2.hp.com/product/opticaldevices/sg/en/pdf/dvd940i_dataSheet.pdf
    RAID 5 installed with Windows XP sp2 now the DVD ROM and ROM not present in Windows
    It sounds like your system may be confusing your dvd drive and somehow including it in the raid array or something.
    Does it see it without the raid setup?
    1helpful
    3answers
    WINDOWS XP
    Windows xp can run on any PC that has a 233 mhz processor and 64mb of ram. Here is a list of hardware requirements for windows xp taken from microsofts website : These are the minimum requirements for basic functionality. Actual requirements vary, depending on the system configuration and the programs and features that you choose to install. If you are installing Windows XP over a network, you may need additional available hard-disk space. The minimum hardware requirements for Windows XP Home Edition are: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600)or higher resolution ? Sound card ? Speakers or headphones The minimum hardware requirements for Windows XP Professional include: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600) or higher resolution ? Sound card ? Speakers or headphones
    Top Microsoft Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
