Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
Herman Poelmann Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony Handycam DCR-TRV19E will not work with my laptop which had Windows7 OS. I get conflicting advice. The Handycan used to work with a USB connection (supplied with camera) on Windows XP. I am now told that unless I have a computer with a Firewire connection I can forget about it. Herman
  • Herman Poelmann Mar 09, 2011
    The very latest driver available is USBDRVEN.EXE which does not solve the issue as it seems I still need a FireWire connection. Is it possibible that the USB cable could be connected to a FireWire converter, i.e fit the FireWire to the camera output and then link it to fit into the USB input of the computer? If such exists, where could one get this?
    Herman
  • Anonymous Aug 10, 2012
    copy the USBDRVEN.EXE to a folder on the C: drive, double click on it - it will explode the files into a the folder you created. run setup from this folder - do the compatiblity mode install when warned. open device manager and update driver for the device with the question mark. select the folder were you exploded the file in the c drive. do the compatible install when warned. restart pc
Anonymous
Level 3:
  • Sony Master 6,771 Answers
  • Posted on Mar 07, 2011
Anonymous
Sony Master
Level 3:
Answers
6771
Questions
0
Helped
1777338
Points
21413
The only suggestion I can give you is contact Sony to see if they can provide you with an updated driver for windows 7 to allow your handycam to work with your computer. Unfortunately when windows changed their operational systems a lot of companies did not offer the required driver upgrade for people that have older units, and even if you went with the Firewire I think you would still run into problems with compatibility issues.
  • Anonymous Mar 09, 2011
    Herman! to be honest I don't know if that would work, and I have never seen such a device let alone if one does exist or not. The only thing I can suggest is do an on line search to see if this converter does exist and see if it will apply to your particular situation.
6helpful
2answers
My sony digital video camera Model DCR-TRV19E is not compatible for Windows 7. What shall i do?
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Could a firewire cable have bent the pins in sony trv19e
If the pins of the cable are broken, better to buy a new one. If the pins of the camara port are broken, a professional may be able to fix it.
Can't find the plug in for Sony Handycan DCR-SR82
HI, The manual for this unit can be downloaded from here.
http://www.docs.sony.com/release/DCRSR42.pdf
Look at page 19 and is shows the USB connection on the docking station for the DCR-SR82. There is no connection on the camera itself.
1helpful
Sony Handycam issue - repair/replace?
Your camera has bad CCD Imager and needs to be replaced this part. Good news is Sony will repair your DCR-TRV19E free of cost. Please check Sony Website for details.
Regards,
NO IMAGE
Hello Shaddy,
DCR-TRV19E has bad/ defective CCD Imager problem.
Sony has started campaign world-wide to replace CCD Imager free of cost. I dont know exactly about Sony policy for your country. Go to following Sony web link in UK and check out.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV19&news_id=161
2answers
Sony handycam dcr-trv19e mini
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
2helpful
3answers
Sony DCR-TRV 140E
Yes got to sony
http://support.sony-europe.com/dime/camcorders/camcorders.aspx?site=odw_en_GB
pick your camera at the bottom, get the USB drivers and that should do. Programs it will work with include Pinnacle Studio etc
1helpful
3answers
Sony Handycam dcr-trv19e
sir, i need driver software for transver my handycam to pc. my handy is sony dcr trv19e
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
