Tip & How-To about Nokia N73 Cellular Phone
Sluggish/slow/memory full n73 solution
My n73 had all kinds of problems like being really slow or unable to open some programs, screen freezes, and stuff like that. This usually means that the phone memory is full of junk that can't be removed and/or viruses. To completely rid yourself of that problem, try hard formatting the n73.
To format
  1. turn phone off.
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
Your phone will gain 44mb back and go back to normal. Phone will respond a lot faster too, as if it were new. Viruses would be deleted as well as other junk stuffed inside.
Important reminder:
If you have anything stored on the phone memory that you woudn't want to delete, such as pictures, videos, or whatever, back it up to your memory card or computer. The format process deletes all stored memory on the phone, but not the memory card.
Nokia N73 Cellular Phone Logo
2answers
why i cannot read,comment or open any windows in my facebook account?
First, small size of RAM makes computer slow. When we use many programs at one time, computer tends to bogged down. Since, uploading/viewing pictures or watching videos on Facebook use many resources, it can result in freeze. This problem can be cured by increasing the size of RAM. An increased RAM size will make sure that enough space is available to run many programs at the same time.
Secondly, corrupt windows registry cause freezes in computer. With passage of time, registry becomes congested and corrupt. Registry is most vital part of the computer system that stores and use vital information.A neat and clean registry ensures smooth and fast computing. Clean registry means no Facebook kind of freezes. For this, you need to use the best registry cleaner. It will solve the problem of such freezes. Registry cleaner reg in out should be used regularly. Additionally, it will speed up computer for all other programs.
3answers
N73 is very slow
Has it always been slow? If not, you could back up all your data (synchronize it to your computer using the software on the CD that came with it,) then perform a hard rest - this will wipe everything off your phone. You can do this through the menus. I believe the option is called "reset to factory settings" or something. You'll then need to copy all the data off the pc back onto your phone. you'll also need to reinstall any applications you installed, this could be bad if you paid for them!
2answers
My N73 too slow
I have my N73ME for 1.5 years, now.
I had same problems. I've tried with log deleting, memory card removing, log setting to 1day - nothing.
Then, I dig through my N73 and I've found LifeBlog application which is incredibly filled with all my messages, pictures and stuff from the 1st day I bought it. Deleting of 5000 records went all night long.
One thing is also good. Before this I did firmware upgrade and now I don't have that annoying bug of being unable to call my contacts from time to time (which requires phone restart to).
may the force be with you!
Benneton
memory low
To format
  1. turn phone off.
Important reminder:
5answers
My N73 Hangs-up After Connecting to My PC
yes
just press this code *#7370# and your phone will be formatted
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
