Check for something caught in the pump or under agitator.
Check that the belt underneath is free running.
This fault is usually associated with excessive current & the motor going out on the auto reset overload.
Could be motor trouble, starting capacitor (If fitted) or the timer.
the fuel pump will run for 2 secondes with key on to prime system. then when you crank engine it should run all the time. you check fuse and if current go to fuel pump at tank connector. if there is current then the fuel pump must be defect.
Sounds like your fuel pump is shot on the fuel rail is a pressure valve looks like a large aluminum valve stem it will have a black cap (caution under pressure) press with small screw driver and look away if your pump is bad it wont spray dont confuse with ac fill port really similar
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
Run Acer eRecovery Management
Copy the Acer factory default backup disk Image
Create backup of the system
Create a complete backup
Creating an incremental backup
Erase a backup point
Using the option ‘‘Burn Disk’’
Burn a backup disc with the factory default settings
Burn a backup disc with the parameters of user
Copy the current system configuration to disc
Burn a disc backup software
Restore the system
Restore system to factory default settings
Restore system from backup user
Recover the system from CD / DVD
Re-install applications / drivers
Other means of System Restore
No Restore CD / eRecovery / password / ALT + F10 or F10
