Refrigerators Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Fridgidaire Electrolux Refrigerator is having the following "problem" - it has BOTH a cubed and crushed ice button. When either is selected (two separate buttons and when one is selected, it turns green), it will still ONLY produces crushed ice. I have tried selecting back to crushed ice, dispensing, and then going back to pressing crushed ice button - still, ALWAYS crushed ice. Any suggestions?
Anonymous
Level 3:
  • Frigidaire Master 3,361 Answers
  • Posted on Mar 07, 2011
Anonymous
Frigidaire Master
Level 3:
Answers
3361
Questions
Helped
1029878
Points
10654
Pull the ice bin forward about 3 inches.
Then re-insert the bin until it locks in place.
2answers
My sisde by side refridge want drop ice oeuither crushed or cube
Refrigerator - Crushed Ice Only, No Cubes. If it appears you are getting only crushed ice from the dispenser, check the following: It is normal to get a slight amount of crushed or broken ice cubes before or while dispensing cubed ice. ... If no ice cubes are behind the bucket, try to dispense ice with the bucket removed.
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
My fridgidaire side by side only dispenses crushed ice even it the setting is at cube. What is the problem
there is a c clip on the solenoid that pulls the rod up to change from cube to crushed its behind the plate on the back where drive motor is
1helpful
The ice maker on my Fridgidaire will only give crushed ice, even though we've never pushed that button. We only want cubes.
check to see if your ice solenoid on the rear of the ice maker bracket is seized up with ice. if so you can remove this and run warm water over to unseize solenoid. remove ice bucket and u should be able to see the solenoid close to rear wall. it is attached to the metal bracket that holds the ice bucket in place. usually two quarter in screws holds it in place
Door ice dispensor will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Ice dispenser crushes ice when cube is pushed
the little gate/door, is a common issue, its a solenoid htat either burns out, or merelt freezes over. if you put your finger into where teh "shepard hook" supposed otgo, can you freely lift it ip and down???i would assum not, .the entire ***,bly lifts out of freezer( remove 2 1/4 inch scres under each corner and diconnect apower plug behind the ice maker. from ther you can try to defrost teh piston,if not rplace it.
4helpful
3answers
Ice maker stuck on ''crushed'' ice
i think it's simpler than that. there's a plastic gate that snaps UP for cubed and DOWN for crushed.
When you remove the tray, set it to CRUSHED, BEFORE putting the tray back in place.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
