Contributor
- Posted on Mar 07, 2011
Re: Theres no lines on the graph, i put in inverse of...
Change your mode (using the Mode button) from degrees to radians. You may also want to consider changing your window settings as you become more familiar with trigonometric functions.
Are you sure it's not graphing, and not that the graph is very close to the x-axis? Or else outside the borders of the graph? The inverse sine of 1/2 is a constant, about 0.5 in radians or 30 in degrees. In the first case at the standard window settings the graph is just above the end of the tick marks on the x-axis. In the latter case the graph is well above the top of the screen.
