Question about Bosch Dishwashers
Display has error code h01 and dishwasher won't run model is SMS63M08AU
    New Friend:
H:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Posted on Sep 19, 2011
  • 4 more comments
  • Cindi Koehler
    Cindi Koehler Nov 23, 2013
    I obviously never used the "delay" feature so I didn't recognize this. Thank goodness!
  • Paula Uzuka
    Paula Uzuka Jan 31, 2017
    Listen, I was so nervous and did not know how we were going to fix this, you are absolutely a godsend!!!
  • Chez Tags
    Chez Tags May 17, 2017
    Mine is doing H:.. all the way to 24 and then starting all over again !! It won't do anything else !! It has been doing it for two full days now !
  • Nicholas Wright
    Nicholas Wright Jun 29, 2017
    Thank you for the answer.
  • Nigel Mock
    Nigel Mock Aug 04, 2017
    We have the same situation a Chez above. We discovered that all you need to do slam the door shut at the precise moment that it hits zero and washing begins.
  • Vi McGuire
    Vi McGuire May 19, 2019
    I can’t get rid of the code.
6ya staff
SOURCE:
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
I have a Westinghouse SB915SJ*00 dishwasher. It runs right through a cycle but does not heat. Any suggestions? Thanks.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Sep 10, 2011 | Dishwashers
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
Fault code H01 appears in the display
You appear to have a pansonic K Mech model.
H01 is the code for no drum motor or drive.
Jan 04, 2009 | Televison & Video
Dishwashers Logo
36,199 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
