The staples are loaded in from the bottom of the unit. Pull out the staple tray all the way to the rear then turn the unit upside down and drop the new staples into the grove in the unit. Push the tray back into the unit and you are ready to go!
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
