You can order the following.
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=5A9ADB3CA5CA7304
I went to crucial.com and input your system and they have the following ram for your system.
you can max out to 8GB of ram however if you do not have a 64bit computer the additional memory will be useless unless you upgrade your OS to windows 7 64bit
Newegg has a great site to find the correct and most compatible memory for you Here.
To maximize your ram speed, use the same speed and types of ram
For example, if you have a 1GB right now, add three more 1GB than putting in a 2GB and 1GB.
If you have a 4GB ram stick right now, add another 4GB and not 2x2GB. Also make sure the MHz on the ram is the same, (1333, 1600, 2000)
Enjoy upgrading your computer!
Just refer to your laptop manual. If your manual got lost go to the acer website and find your product and download the manual.http://www.acer.com.ph/ac/en/PH/content/home .
when upgrading your memory you have to consider the following:
the processor: if your processor has 4gb compatibility mem you can upgrade upto 6 to 8gb.
take note that you must not exceed to 8gb or else your processor might be damage.
get the processor speed: example core 2 i3 processor, 1.0GHZ-the frequency.
the Memory or RAM(random access memory): get ther specification: example is DDR1 or DDR3
PC133 or PC 400. Thats all.
Note: your current memory must have the same memory module(example PC400,PC 133) or else it wont work.if your going to upgrade your current 4gb PC400 you have to add 4gb memory in PC400 module also.
