1) you must LUBE THE DECK BELT+ ROLLER BEARING.
2) Test the input voltage motor, if there are the MOTOR is faulty need REPAIR.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) SEE THE BLOCK DIAGRAM, whatever component can be faulty.
However you must test the power cord for short circuit between cable, repair, and look inside according the BLOCK, and proceed with logic, see any loose wires, or some wires touching the carcase, some filter, coil, power supply USE the VOM.
God bless you
