Radio Shack Pro-84 Handheld Scanner Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I DON'T HAVE A MANUAL FOR MY PRO-84 SCANNER...WUD LIKE TO JUST CLEAR THE FREQ AN RELOAD POLICE AN FIRE FOR MY AREA. HOW DO I DO IT?
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Mar 06, 2011
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
934148
Points
7369
To clear (RESET) the scanner:
- Power it OFF
- Press and hold the 2, 9, and HOLD keys and power the scanner ON
You can download and print the factory manual for your scanner, at no cost, here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000516_PM_EN.pdf
Bill B.
Listening in since the 60's
Can i get new frequencies for my radio shack police scanner handheld here in iowa?
Go to this website for listing of frequencies in your area. http://www.radioreference.com/apps/db
This is a great resource for programing your scanner.
Pro 84 scanner how to search for frequencys between 144.00 and 148.000
You can download a copy of the user's manual here if you need it. It doesn't look like you can set your own scan range, but you can have the scanner search by pre-defined service. Here's what the manual says about searching:
service search
You can search for weather, ham, marine, aircraft, or
police (fire/emergency) transmissions without
knowing the specific frequencies used in your area.
The scanner is preprogrammed with all the
frequencies allocated to these services. To use this
feature, press FUNC + SVC. SRCH appears and the
scanner searches starting with the weather service
bank. To select a different service bank, repeatedly
press FUNC + SVC. Service mode appears on the
display.
When the scanner stops on a transmission, quickly
press HOLD to stop searching and listen to the
transmission. HOLD appears. In this mode, you can
press FUNC + ^ or FUNC + v to step through
the frequencies.
To release the hold and continue searching, press
HOLD. Or, if you did not press HOLD, simply press
FUNC + ^ or FUNC + v to continue searching.
It goes on to explain how to store frequencies as you find them while searching.
I don,t know how to program my pro 2038 police and fire scanner.
Your scanner cannot be programmed in the normal manner - entering the frequency via the keyboard. Rather, you can only transfer a displayed freq from SEARCH or SCAN and transfer it into the PRIVATE bank. Details for doing this are outlined in this Radio Shack document:
http://support.radioshack.com/support_electronics/doc18/18273.htm
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
5helpful
Need to do a master reset on pro 84 sanner but don't have manual
To RESET the PRO-84, turn the scanner OFF, then hold in the 2, 9 and HOLD keys and power the scanner ON. The word CLEAr will appear on the display to confirm the RESET.
While the manual for the PRO-84 has not been posted by Radio Shack, it is essentially a red PRO-83. You can download/print the 83 manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
2helpful
2answers
Free police frequincies
For a comprehensive database aO active frequencies and systems in your area, along with a lot of other useful scanning information, visit:
Bill B
1helpful
Pro96 PROBLEM
http://www.police-scanner.info/police-scanner-frequencies.htm you may need to put in the new freq. # a few months ago most went to new freq. #
2answers
Need to upgrade firmware
http://www.police-scanner.info/police-scanner-frequencies.htm I was told i had to get a new scanner when most freq.# changed but all i did is go to this site and got the new freq.# put them in and get more then i had.
1helpful
4answers
2answers
New Zealand
Do you have a list of correct freq's for your area?
Make sure you have the scanner set on the correct mode (am/fm/ct/dc) for the freq's you have programmed. Each area of the country have their own individual freq. so their not stepping on each others transmission.
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
