Canon PIXMA iP4000 InkJet Photo Printer Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magenta not printing properly. Have done several cleans, deep cleans and changed cartridge. On nozzle check the darker band of magenta prints ok but the paler band prints half pale and other half darker. Prints come out with the last 2inches with vertical bands.
Anonymous
Level 3:
  • Master 310 Answers
  • Posted on Mar 06, 2011
Anonymous
Master
Level 3:
Answers
310
Questions
Helped
125234
Points
1026
If you have clean the print head several times,the problem is the prin head,you need to replace.
  • stevelz Jul 09, 2014
    Sounds like your ink cartridge is starving on the magenta side. This could be caused by either the cartridge is clogging while printing, or the contacts may not be making good contact and when the printer is printing, the contact is broken. Try cleaning the contacts with rubbing alcohol. Make sure the printer is turned off when doing this. Make sure that all the contacts are dry before restarting the printer. Another thing that you can try is to get a paper towel and fold it into a 6 inch square. Wet one half of the top side of the towel and leave the other side dry. Now put your ink cartridge on the wet side and drag it across the towel into the dry side. This some times unclogs the cartridge. Keep in mind that you do not put downward pressure on the cartridge. to much force could ruin the nozzles and you will have to replace the cartridge.
My printer is not printing magenta. I have changed the cartridge (hp one), cleaned the print heads and
The magenta print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked magenta print nozzles. Also check the magenta cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
2answers
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
Printing photo's colour comes out green
This probably means that only the cyan and yellow cartridges are delivering ink i.e. magenta isn't. This could be because the magenta cartridge is empty or faulty, or because the ink jet nozzle is blocked. Alternatively it could be a faulty print nozzle or faulty main board. The best approach is to first try a print head cleaning cycle and printing a nozzle check. Repeat the cleaning cycle and nozzle check 2 or 3 times. If this produces magenta, but not perfectly, leave it for 24 hours and then repeat the process.
If this fails, you must then make sure you have a good magenta cartridge by changing it for a new one. Save the old one - you can always use it again later if it turns out to be OK. Make sure you use the proper cartridge exchange process to do this so that an ink charging cycle takes place. Then try another nozzle check.
If this doesn't solve the problem, you can try soaking the print head as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
2answers
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
old marine
old marine
ZJ Limited
ZJ Limited
